The Mitutoyo CRYSTA-Apex EX 500T/700T/900T PH20 Equipped 5-Axis CNC CMM are equipped with the PH20 5-axis control touch trigger probe. The 5-axis operation reduces the time required for probe rotational movements and allows for more flexible positioning.
