The very large Mitutoyo FALCIO Apex 2000/3000 Series 355 High Accuracy Large CNC CMM provides a large measuring range of 80” x 120” x 60” (2000mm x 3000mm x 1500mm) to 120” x 200” x 80” (3000mm x 5000 mm x 2000mm).
