The Mitutoyo STRATO-Apex 500/700/900 Series 355-High Accuracy CNC CMM are high-accuracy, achieving 0.9µm for the first term. The series guarantees high accuracy and also high moving speed and acceleration achieved with improved rigid air bearings on all axial guideways.
